Activity › Forums › Adobe After Effects › CC Vector Blur Path
  • Michael Szalapski
    October 4, 2017 at 2:00 pm
    Does it have to use CC Vector Blur? The examples you’re showing all look like Radial Blur (or similar).
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
  • Lorenzo Farò
    October 4, 2017 at 2:12 pm
    Obviously I’m not fixed on the option it’s vector blur, but’s the one that is more similar.
    Also, I tried a radial blur but if you observe the pics the blur has at least two different directions and angles.
    If you have any other idea I’ll be glad to accept it 🙂
  • Kevin Camp
    October 4, 2017 at 6:51 pm
    i’m not sure what you are using for your vector blur map, but i think if you use a simple radial gradient on a solid (or shape layer) as the vector map you should start to get a ‘zoom blur’ effect. tweaking angle and other settings may get the effect you are looking for.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Pierre Jasmin
    November 10, 2017 at 6:50 pm
    FYI (sorry for the advertising)- you can always try SmoothKit Directional With Splines (in SmoothKit plugin by us, RE:Vision Effects), it allows you to shape directly a blur using AE masks. It takes a bit to understand how to control falloff with soft mattes…
    Pierre
