Activity › Forums › Adobe After Effects › CC Time Blend FX not appearing in Adobe After Effects CC
Posted by Usman Pirzada on July 13, 2015 at 6:02 pmHey guys, so I really need to use the Time Blend FX and recently updated to CC from CS6. But the Time Blend FX plugin is nowhere to be found. I can confirm that it is actually present in the plugins directory like its supposed to be – it just doesnt show up in CC? what gives/ 🙁 I have tried changing color modes and refreshing the preference file so far….
Jens Enqvist replied 10 years, 8 months ago 7 Members · 8 Replies -
Todd Kopriva
July 13, 2015 at 7:23 pmCycoreFX removed CC Time Blend and CC Time Blend FX from version 1.8.0, the version included in After Effects CC 2015 (13.5). See the notes at the end of this:
what’s new and changed in After Effects CC 2015 (13.5)
After Effects product manager and curmudgeon
After Effects team blog
Usman Pirzada
July 13, 2015 at 10:47 pmThank you for answering but why 🙁 If they did that, why isn’t there any substitute plugin?
Kevin Camp
July 14, 2015 at 7:50 pmi wonder the same thing… they don’t mention anything on their site, but you can email them: support@cycorefx.com
Kevin Camp
Art Director
KCPQ, KZJO & KRCW -
Corrie Parks
October 14, 2015 at 2:24 amDid you ever get an answer as to why this was deemed obsolete and if there is a substitute? I use this as well, for a very particular type of frame blending to replicate a staggered mix in under-the-camera animation. It saves a lot of work. I even had it highlighted in a tutorial in a book that is about to be published and now we have to go revise the manuscript.
I would definitely like to know if there is something equivalent.
Michael Szalapski
October 14, 2015 at 2:19 pmUntil Cycore responds, the good news is that, with Creative Cloud, you can install every version of AE back to CS6, so, if you really want CC Time Blend, you can load an older version and use it.
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Caleb Mclaughlin
November 12, 2015 at 3:58 pmDepending on your project, you might be able to use Echo instead. I’m using it for star trails in a pinch. Would rather have Time Blend, but this will work if you need a quick blend without opening another version of AE. You just have to get used to the Echo Operator terminology in place of the blend modes.
Caleb
Corrie Parks
November 28, 2015 at 4:09 amYeah, I’ve played around with Echo and with some of the other time effects. It just isn’t as versatile. I hope they bring it back!
Jens Enqvist
December 2, 2015 at 2:57 pmThey are actually both included still but marked Obsolete which means they will not show up in the effect menu. If you open an old project with layers having the effects applied, they will however show up in the effects window.
