Activity › Forums › Adobe After Effects › CC Sphere Rotation
  • CC Sphere Rotation
    Posted by Vince Becquiot on December 25, 2005 at 1:54 am
    For all you math gurus, I have (I imagine) a simple question.
    I am using cc sphere to achieve an earth rotation and expressions to a match Grid sphere rotation over it.
    When I rotate the x Axis using key frames, I can easily change the Y axis to anything I want, but as soon as the z axis is changed , (obviously ?) my north pole is all over the map.
    Any help with this?
    Thanks a million…
    Vince Becquiot replied 20 years, 9 months ago 5,686 Members · 1 Reply
  • Vince Becquiot
    December 25, 2005 at 4:46 am
    Well I partly figured it out. Somehow I was using the sphere effect value instead of the layer transform value.
    Although only the z value can be used there, since the other values affect the shape of the sphere.
    But by playing with both x and y values on the sphere and the z transform value I was able to move things the way I wanted to, while keeping the rotation on the same axis.
    Vince
