Activity › Forums › Adobe After Effects › CC Sphere: pin 3D-layer to specific point on a sphere
Posted by Stef Prein on May 25, 2012 at 9:36 amHi!
Is it possible to pin a 3D-layer to CC Sphere, so the layer moves and rotates with it? Couldn’t find a solution yet. And I know this questions has been posted a week earlier, but no one gave an answer.
Thanks in advance!
Stef Prein
director/motion designer at StudioFets.
Utrecht, The Netherlands
http://www.studiofets.comStef Prein replied 11 years, 4 months ago 4 Members · 8 Replies -
John Cuevas
May 25, 2012 at 11:59 amCreate your CC sphere layer and set up the layer but leave it in the center of the comp.
Add a null object to your comp and turn on it’s 3d switch. Open the rotation properties of the Null, enable an expression for XYZ rotation and pick-whip it to the CC Sphere’s rotation and at the beginning of the expression add a minus sign(you want to the result to go backwards to match the rotation). Add and expression to the Null’s position and pick whip that to the CC Sphere Offset so if you move the sphere your controller will follow.
Enable 3d for the CC sphere layer and ignore any warnings. Now just parent the layer you want to orbit the sphere(pinned to the sphere) to the Null.
You can even add a camera to the scene if and keep the sphere layer by using cntl+alt+o and change the sphere layers orientation to “Orient to camera” to avoid the postcards in space look.
I made a quick example project where you can see the results with and without a camera.
4202_exampleproject.aep.zipJohnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
Stef Prein
May 25, 2012 at 2:58 pmHi John,
Thanks! That’s exactly what I’m looking for! And yes, I should have thought of this… I’m glad you did!
Cheers,
Stef Prein
http://www.studiofets.com -
Nikolya Gousteau
May 26, 2012 at 3:56 pmHi John!
Thank you a lot for suggesting this solution. However, several things remain unclear for me:
1) When we pick-whip the Null position to CC Sphere offset, we want the Null to be “pinned” to the center of the Sphere, right? However when I watch your composition, this is not exactly so…
Here is a link to the rendered “Example project” comp from your project:
link
(I’ve just added a red circle to visualize the Null, and set the opacity of Sphere to 50 to reveal the Null)2) Even when we turn off the animation of Sphere offset, if we try to place the Solid exactly on the surface of Sphere, there is a problem. Here is a link to a video-description of the problem:
link
To place the Solid on the surface, I just set its Z-position to -R, R being the radius of Sphere (note that Solid is pick-whipped to Null so its position is relative with respect to Null). What is wrong in this case?Thank you in advance!
P.S. Here is a link to the project file: 4210_solutiondiscussion.aep.zip
Nikolya Gousteau
May 26, 2012 at 4:10 pmIt appears that I’ve just solved the problem 2)
In the expression for Null position I wrote
temp = thisComp.layer("CC Sphere Layer").effect("CC Sphere")("Offset");
[temp[0], temp[1], 0]
instead of
[temp[0], temp[1], temp[1]]The question 1) remains.
John Cuevas
May 27, 2012 at 2:16 amtemp = thisComp.layer("CC Sphere Layer").effect("CC Sphere")("Offset");
[temp[0], temp[1], temp[1]]The problem was in pick-whipping the null position to the offset. It escaped me that the z position is being fed the y-position value from the CC Sphere Layer(temp[1]). After Effects does this because there is no Z position value from the sphere, so the nulls z position by 243 pixels. That’s why everything was off.
The solution is to go to the null’s position property and right click on it and choose separate dimensions. Then individually select the x and y position of the null and link them to the sphere’s xy offset.
Sorry about the mistake, I previewed it quickly and thought I had caught everything.
Nikolya Gousteau
May 27, 2012 at 8:47 amThat’s OK, at least now I understand better how CC Sphere works.
I’ve also experimented with camera, and came to conclusion that CC Sphere doesn’t treat the perspective the same way as After Effects.
I tried 15 mm camera and 200 mm camera, and CC Sphere doesn’t seem to be effected by this feature. But the solid layer is dramatically effected by it. Here is an illustration:It appears that only 200 mm camera gives good result compatible with CC Sphere.
P.S. A link to the project file: 4212_solutiondiscussionfinal.aep.zip
Paul Murphy
May 1, 2015 at 11:57 amThis tutorial shows you how to link a 3D object to CC Sphere:
https://vimeo.com/126553140Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Stef Prein
May 2, 2015 at 2:19 pmHaha thanks! I had completely forgotten about this post.
Stef Prein
director / motion designer at StudioFets.
