Activity Forums Adobe After Effects CC Sphere not working
  • CC Sphere not working
    Posted by Austin Thompson on January 27, 2013 at 5:55 pm
    So I got a map of earth and in premiere I placed a few videos on top of that map. I then imported that project into After Effects so that I could use cc sphere and make a globe.
    But it’s not making a sphere. The top and bottom are completely blank. If I run cc sphere on just the map, it works perfectly, but when I run it on the map with extra videos on top, it’s this sphere with the tops and bottoms cut out (I can see the inside of earth at the poles)
    So is there any way to merge down everything onto just the map layer? Where am I going wrong?
    Vishesh Arora replied 13 years, 7 months ago 3 Members · 6 Replies
  • Vishesh Arora
    January 27, 2013 at 6:25 pm
    Austin
    Put the Map and Videos in one comp and make sure there is no blank space is left. This means that the comp covers everything completely and there is no blank space left.
    Now apply CC Sphere to the Comp.
    A screenshot of Composition panel with the map and videos on it would solce the issue.
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    2011 3D Demo Reel:
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • Austin Thompson
    January 27, 2013 at 7:39 pm
    I’ve been trying that, but is there a way to force the comp to take on the dimensions of the project? It keeps trying to push the project to fill the comp settings
  • John Cuevas
    January 27, 2013 at 8:20 pm
    What Visesh means is you need use a precomp to do this. Drag your map on to the make new comp icon in the project panel. Now place your videos over the map, spacing them out in the timeline. Press “Cntl+K” and rename this comp “Map Precomp”
    Now make a make a new composition “Final” with your final dimensions. Take “Map Precomp” and drop it into your final composition. Now apply the CC Sphere effect to the “Map Precomp” layer.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Austin Thompson
    January 27, 2013 at 8:38 pm
    Oh…thanks! I think I was trying to take 15 shortcuts simultaneously. When I just burnt it all and started from scratch and used your suggestions, it worked perfectly first time. Thanks so much to both of you!!!
  • John Cuevas
    January 27, 2013 at 10:46 pm
    Glad you got it worked out and we were able to help.
    Thinkck.com
  • Vishesh Arora
    January 28, 2013 at 6:03 am
    Thanks John for explaining the procedure clearly 🙂
    Vishesh Arora
    Films Rajendra
    Blog:
    2011 3D Demo Reel:
