Activity › Forums › Adobe After Effects › CC Sphere image blurry
  • CC Sphere image blurry
    Posted by Heather Crank on November 11, 2009 at 9:44 pm
    Hello Everyone,
    I’ve got a great spinning globe. When I add a camera and zoom into the continents, they look blurry (I’ve used a high res image for the earth map). Is there a way to work around or fix this without a 3-d program?
    H
    Heather Crank replied 16 years, 10 months ago 4 Members · 5 Replies
  • Kevin Camp
    November 11, 2009 at 9:50 pm
    how are you zooming in?
    if you are using scale, you might try increasing the radius in cc sphere to see if that helps
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Heather Crank
    November 11, 2009 at 9:52 pm
    Hey Kevin,
    I was using the z-axis of the camera…I’ll try scale and see if that works better.
    Thanks!!!
  • Scott Novasic
    November 12, 2009 at 3:26 am
    that is one of the downsides of some 3d plug ins. They dont scale high rez imagery the same way a true 3d app interpolates one.
    SuperNova
    Animation & Visual Effects
    Scott Novasic
    Los Angeles Ca
    web:https://web.mac.com/finaleffects
  • David Bogie
    November 12, 2009 at 3:56 pm
    CC Sphere is not a 3D plugin, it just maps a layer to a simulated 3D object.
    CC Sphere will hold resolution if you precompose it properly and use the correct scaling/zooming operation. Using a comp camera will yield a different result than using the camera in the filter.
    bogiesan
  • Heather Crank
    November 12, 2009 at 5:06 pm
    Thanks, adjusting the scaling is working like a charm!
    H
