Activity Forums Adobe After Effects CC Sphere effect question?
  • CC Sphere effect question?
    Posted by Justin Kauer on January 10, 2008 at 2:03 am
    I’m applying CC Sphere to a very large, high res photo in hopes the I will be able to zoom into a world without pixilation. However this is not the case. I have continual rasterize checked so i’m assuming it’s an effects limitation? Does anybody know a work around, or maybe what i’m doing wrong? Or of any other effect that might work better?
    Thank you in advance..
    Justin Kauer replied 18 years, 8 months ago 2 Members · 2 Replies
  • Peter Van der zee
    January 10, 2008 at 9:55 am
    Check the effect settings, Sphere has a radius; if you leave it small and zoom in you loose quality, you can make the sphere any size you want, but you’ll have to put it in a huge precomp. That will give you the resolution you want in your comp.
    vanderzee.tv
  • Justin Kauer
    January 10, 2008 at 6:14 pm
    Your right! Thanks for the help..
