Activity › Forums › Adobe After Effects Expressions › cc sphere
cc sphere
Posted by Rdub on May 31, 2005 at 4:57 amWhen I apply cc sphere my image looks like a flat rectangle. Where is the best place to find a tutorial of some kind online?
Steve Roberts replied 21 years, 3 months ago 4 Members · 5 Replies -
Filip Vandueren
May 31, 2005 at 2:33 pmWhat kind of image are you starting out with ?
Is the layer you’re applying it to large enought to contain the cricle ? -
Rdub
May 31, 2005 at 6:46 pm2048×1024. I imported a map/texture from the NASA site. Applied cc sphere. Reduced the radius. Still looks like a flat circle. Can’t rotate a flat circle and have it look like a world.
Filip Vandueren
May 31, 2005 at 10:11 pmI’m presuming you’re having the layer as a 3D layer.
The CC Sphere effect renders a 3d layer on a flat layer, so don’t rotate the layer, rotate the effect.
A first step would be to auto-orient the layer to always point to the camera.
I did some work on some expressions that totally emulate the look of a ‘true’ 3d sphere by measuring the distance to the 3D camera and a light source, but it’s not quite done yet:
check out this thread:
https://www.creativecow.net/forum/view_thread.php?threadid=828066&forumid=2&postid=111605765777943
Steve Roberts
June 2, 2005 at 11:10 amFilip’s right on.
There are quite a few mock 3D effects in AE. They basically make a “movie” of a 3D object, using AE’s layer as a sort of projection screen. If you were to make the layer “3D” then rotate it or whatever, you’d be rotating the projection screen, and that’s what you saw.
That’s why a lot of those effects give the little warning that they are to be applied to 2D layers.
(Unless you want to see a rotated flat projection screen for some reason.)
Steve
