Activity Forums Adobe After Effects CC Sphere
  • Posted by Peter Mueller on October 4, 2014 at 10:44 am
    hi everyone! can somebody help me with this:
    when I use the cc cphere effect on a solid I got not a sphere but a ellipsis shape as you can see on the picture.. i can’t find the reason for this..
    thanks a lot
    peter
    Peter Mueller replied 11 years, 11 months ago 2 Members · 2 Replies
  • Roland R. kahlenberg
    October 5, 2014 at 12:24 am
    Your image/layer is not formatted with square pixel aspect ratio (PAR). Your workflow to correct this is to create a comp that is the square PAR equivalent of your non-square PAR image/layer. Then fit the image/layer to match the size (CTRL+F) of this square PAR comp. Then nest this comp and apply CC Sphere.
    This is another reason why folks should always work in square PAR comps. Should you require to output to a non-square PAR, then nest your square PAR into a non-square PAR comp at the last step – just prior to rendering.
    HTH
    – Roland
    TypeGEMs – the Definitive Type Gizmo for AE
    https://broadcastgems.com/typegems/
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Adobe After Effects CC ACE/ACI
    Imagineer Systems (mocha) Certified Instructor
    https://www.broadcastgems.com/mographintensity_shapestext/
  • Peter Mueller
    October 5, 2014 at 8:07 am
    Yea. TFTH Roland 🙂
