Activity › Forums › Adobe Premiere Pro › CC RepeTile in Premiere Pro?
Posted by Grant Muir on February 18, 2020 at 2:07 amIs there an equivalent of CC RepeTile from AE in PP?
Grant Muir replied 6 years, 7 months ago 2 Members · 2 Replies -
John Williams
February 18, 2020 at 10:48 amHi there, you can get a plug-in for this but if you want to do it manually can copy the clip and on the copy use the Flip effect (Vertical Flip & Horizontal Flip) and then position the clips next to each other so they are mirrored. (Best to do this with the clips at full size and then bring the result into your main edit as a nested comp.)
However, it’s probably still faster sending it to After Effects and back;)
John Williams
Soho Editors
Grant Muir
February 18, 2020 at 10:35 pmYeah I’ve been doing it in AE & linking in PP, but was hoping to not have to do that as I’m working with a lot of files.
What plugin would I be looking for?
