Activity Forums Adobe After Effects CC render quits with an error msg….
  • CC render quits with an error msg….
    Posted by Chris Borjis on July 10, 2013 at 9:41 pm
    I did try clearing all the cache options, still would not work.
    I can reboot, then it will render out. If I open another project,
    then send to queu and render it crashes, requiring another reboot.
    There is 1/2 a terabyte free on this volume, I tried another with 3TB free
    so it’s not a free space issue. of course this happened when I had a
    deadline to meet. 🙂
    AE CC Mac.
    Toma Ever replied 13 years, 1 month ago 4 Members · 5 Replies
  • Walter Soyka
    July 11, 2013 at 4:08 pm
    Any third-party plugins in use? Are they up-to-date?
    Is that volume direct-attached, or networked?
    Does it happen if you render to a different format or a different volume?
    Walter Soyka
  • Chris Borjis
    July 11, 2013 at 5:27 pm
    no third party plugins
    volumes are fibre channel & pci-express direct connect.
    yes it also happens if I render to a different volume.
    one thing I did notice, I hadn’t yet had a chance to set
    the render settings for multi-processor, when i enabled
    that, it seems to not have the problem.
    Octocore mac, 16gb ram, mountain lion.
  • Toma Ever
    July 29, 2013 at 1:14 am
    Hello,
    I have the exact same problem, it is really enoying; sometimes the error pops up straight away after i clicked on the render button, sometimes during render…
    To make it work, i use the script “background render”. I also tried to repair permissions , then launch again the render queue, that seems to work too.
    But a real solution would be really welcome!
  • Todd Kopriva
    July 29, 2013 at 3:02 am
    AJA, BlackMagic, or other third-party video hardware installed?
    After Effects team blog
  • Toma Ever
    July 29, 2013 at 8:28 am
    console message:
    7/29/13 4:18:41.479 PM Adobe QT32 Server[9221]: Error loading /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType: dlopen(/Library/QuickTime/LiveType.component/Contents/MacOS/LiveType, 262): Library not loaded: /Library/Application Support/ProApps/SharedA/Frameworks/LiveType.framework/Versions/A/LiveType
    Referenced from: /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
    Reason: image not found
    don’t have livetype installed, that’s weird! but I have copied quicktime codecs from another computer into my fresh install of osx 1.8.4 on macbook pro retina. Could that be the issue ? I see a livetype.component, i copied it by accident, now deleted. Will see how it goes for my next renders…
