Activity › Forums › Adobe Premiere Pro › CC Premiere – Full mp4 export process to produce only a 24kb file.
  • CC Premiere – Full mp4 export process to produce only a 24kb file.
    Posted by Stefan Day on January 18, 2016 at 6:48 pm
    Not sure what’s going on here.
    Via file > export media I am setting an HD sequence to encode to the Vimeo HD 29.97 preset for H.264.
    The sequence is approx. 2hrs long. The software runs through the full encode process.. several hours then turns out an .mp4 that is only 24kbs. I have repeated this process twice with the same outcome.
    I have done this SAME process many times before without a hitch. Nothing has changed, that I am aware of, with my setup.
    Any clues on what might be happening?
    Tero Ahlfors replied 10 years, 8 months ago 3 Members · 2 Replies
  • Jeff Pulera
    January 18, 2016 at 10:22 pm
    Clean out the Premiere cache.
    Make sure Destination drive has adequate space available.
    Make sure export filename path is not extra long.
    Make sure filename does not contain “special characters” reserved for system use, like punctuation and such. Keep it simple.
    I would make appropriate changes if applicable and try a short export segment before committing to the long render of full movie again.
    Jeff Pulera
    Safe Harbor Computers
  • Tero Ahlfors
    January 19, 2016 at 7:32 am
    Also make sure you have selected the correct source range.
