Activity › Forums › Adobe After Effects › CC Plugins
CC Plugins
Posted by Mike Jenkins on June 23, 2008 at 1:26 amHey there,
I’m having loads of trouble trying to find any sort of CC presets & effects for my After Effects CS3.
Is there any way I can download a bundle pack of these? Because a bunch of tutorials use the CC presets.
– Thanks.
Sammy Sparkel replied 13 years, 7 months ago 7 Members · 6 Replies -
Kevin Camp
June 23, 2008 at 11:47 amthe third party bundled effects (like cc effects, keylight and color finesse)are on the ae install disk. they normally install by default with cs3, but if they didn’t you should be able to install just those effects from the installer.
if you have the downloaded trial version they may not come with those effects… but i’m not sure.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Mohammad Taghi karimi
June 25, 2008 at 4:56 pmyeah yeah yeah
there is a way if u are useing try version of after effect
u must use these links to download cc plugins then copy them to ur plugin folder of ur after effect installing folder
https://www.4shared.com/file/25074694/ae87e20a/AfterEffectsPluginCycoreFXHD10Manual.html?s=1
https://www.4shared.com/file/17518663/3b30a607/After_Effects_Plugin_-_Cycore_Cult_Fx_v15.html?s=1if any help i can do for u juz tell me and i’ll answer it
Just Try To Be Best Until You Death
Never Give Up For Any Thing
http://www.mtkarimi.com -
Nehal Hussien
December 10, 2009 at 4:13 pmMohammed
thank you
thank you
thank you
thank you
you just made my day 🙂
& thanks kevin for keep helping us 🙂Nehal,
Egypt -
Vignesh Sundar
August 11, 2011 at 8:40 amI need CC jaws,CC Radial scalwipe,CC Pixely poly,CC Vector Blur, CC Particle world… plugins any 1 pls send me the link for it pls
Sammy Sparkel
February 12, 2013 at 8:15 amPls I am also in d same problem, how can I get the link 2 all cc pluggin effect for cs5, pls can any help me
