Activity Forums Adobe After Effects CC Particle World Keyframing Not Working?
  • CC Particle World Keyframing Not Working?
    Posted by Isaiah Bugarin on August 5, 2011 at 2:13 am
    I’m editing a clip and I’m trying to keyframe the “Max Opacity” property in the “CC Particle World” effect in AE. For some reason, whenever I try to keyframe this, it doesn’t work. If I’m not keyframing it, however, the opacity property works as it should. I’ve tried all the properties in the effect, and I’ve got the same result. They simply don’t work when I try to keyframe them.
    Walter Soyka replied 15 years, 1 month ago 2 Members · 3 Replies
  • Walter Soyka
    August 5, 2011 at 2:54 am
    [Isaiah Bugarin] “I’m editing a clip and I’m trying to keyframe the “Max Opacity” property in the “CC Particle World” effect in AE. For some reason, whenever I try to keyframe this, it doesn’t work. If I’m not keyframing it, however, the opacity property works as it should. I’ve tried all the properties in the effect, and I’ve got the same result. They simply don’t work when I try to keyframe them.”
    Many values for individual particles are set at their birth. When the value of a property like max opacity changes, it will not affect particles which have already been born — it will only affect particles born after the change.
    Walter Soyka
  • Isaiah Bugarin
    August 5, 2011 at 3:01 am
    Thank you very much! Although, this still didn’t solve the problem I’m having. Is there a way to ‘force’ a new set of particles to set at a certain point?
  • Walter Soyka
    August 5, 2011 at 1:51 pm
    [Isaiah Bugarin] “Is there a way to ‘force’ a new set of particles to set at a certain point?”
    I’m not sure I understand your question.
    Can you describe the visual you’re trying to achieve?
    Walter Soyka
