Activity Forums Adobe After Effects CC Particle World Ignoring Birth Rate
  • CC Particle World Ignoring Birth Rate
    Posted by Jon Mitchell on March 19, 2014 at 3:13 pm
    I’m creating a fun kid spot with shapes generating from a central point. All five particle emitters (CC Particle World) are producing WAY too many particles. I have the Birth Rate set to .032 and they’re all still producing 10+ particles a second. I’ve jigged with the settings for 30 minutes and had a co-worker take a look. Neither of us understand what’s happening.
    Does this issue sound familiar to anyone?
    Jon Mitchell replied 12 years, 5 months ago 3 Members · 6 Replies
  • Walter Soyka
    March 19, 2014 at 7:44 pm
    If you are on Ae CS6 or higher, try emptying the disk cache and making sure all updates are applied.
    Walter Soyka
  • Jon Mitchell
    March 19, 2014 at 7:57 pm
    Dave,
    thanks for that tip, I’ll add that one to my tool belt. Unfortunately, it didn’t work in this scenario. :/
    Here’s settings and output:
    Shouldn’t it be producing only a handful of hearts? Is something goofy with the source layer/image?
  • Jon Mitchell
    March 19, 2014 at 8:32 pm
    No dice on that one either. Thanks though.
  • Kevin Camp
    March 19, 2014 at 11:20 pm
    particle world isn’t designed to do low numbers of particles, so you might try a different particle system.
    I think foam would work for you. you can set a custom particle in rendering>bubble texture, then choose your heart layer for the bubble texture layer.
    in the physics settings you can change the speed and direction and you’ll probably want to set the wobble amount to 0.
    after that the settings are similar to most other particle systems.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Jon Mitchell
    March 20, 2014 at 1:39 pm
    Dave, .032 is the lowest Particle World will go for me. Below that it generates nothing.
    Kevin, what you saying makes a lot of sense. Probably should have given that a go first. I just could’ve swore I used Particle World for low number particles before…
  • Jon Mitchell
    March 20, 2014 at 4:50 pm
    Kevin, what you saying makes a lot of sense. Probably should have given that a go first. I just could’ve swore I used Particle World for low number particles before.
    EDIT
    Hey, foam works perfect. Thanks for the suggestion.
