Activity Forums Adobe After Effects CC Particle Effect Wont Show up?
  • CC Particle Effect Wont Show up?
    Posted by Shawn Mall on August 23, 2010 at 11:00 pm
    Im trying to do a tutorial that uses CC particle world, but when i add the effect, and do the exact steps, the effect isn’t showing up… specifically im using the lens convex particle, and nothings showing up.
    What do i do to make it visible?
    Sharell Jordan replied 10 years, 4 months ago 3 Members · 2 Replies
  • Karl-jason Mawdsley
    August 24, 2010 at 8:35 am
    The lens convex particle type gets it’s colour value from the layer you place the effect on. So if you’ve created a black solid and applied that particle type to it, you won’t see it against a black background. Try changing your solid colour to white.
    If that’s not the problem then if you can give me some more details about the steps you’re taking, I’ll try my best to help.
    KJ Mawdsley
    Editor/Mograph Designer
  • Sharell Jordan
    April 25, 2016 at 4:21 am
    This worked for me just now. Thank you so much.
