Activity Forums Adobe After Effects CC Page Turn: Can’t render page flip with full opacity
  • CC Page Turn: Can’t render page flip with full opacity
    Posted by Chris King on March 3, 2013 at 11:00 pm
    I created a simple page flip using CC Page Turn and want to pages to be fully opaque and non see-through. I set the Back Opacity to 100% in the effects panel and the overlapping pages look perfect in the comp. I render it out at:
    ProRes 422 (LT)
    RGB
    Millions of Colors
    Premultiplied (Matted)
    and export. Then when I open the render, the page being “flipped” is see-through. Retried it several times adjusting the Premultiplied option to Straight, double-checking the Back Opacity, same result. The most frustrating part is it looks fine in the comp, it’s just the render that is having issues.
    Any idea how to render it without the layer being opaque?
    Vishesh Arora replied 13 years, 6 months ago 3 Members · 2 Replies
  • Paul Roper
    March 4, 2013 at 2:20 pm
    ProRes 422 doesn’t support alpha channels – you’ll need to render it using another codec, such as ProRes 4444 or an image sequence. Just make sure, when you render, to click on the render setting, and make sure it’s set to RGB+Alpha in the Channels pop-up.
    – Paul
  • Vishesh Arora
    March 5, 2013 at 10:51 am
    Chris
    ProRes 422 (LT)
    RGB
    Millions of Colors
    As Paul has said, You are not rendering the footage with Alpha Channel.
    RGB
    Millions of Colors
    Implies that there is no Alpha channel.
    The Output Module Settings should look like this:
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    2011 3D Demo Reel:
    https://www.youtube.com/watch?v=lHPgIJU_BR8
