Activity Forums Adobe Premiere Pro CC Multicam
  • CC Multicam
    Posted by Gabriel Regalbuto on July 15, 2013 at 11:38 pm
    I edit multicam shoots with matching time of day code, sending the cut timelines to DaVinci. I wasn’t able to use CS6 because it would not reference the original sources in an xml export, only the timecode from premiere’s own virtual clips. Is this fixed in v.7? Can I easily create a multiclip timeline with matching code like in FCP7?
    Herb Sevush replied 13 years, 2 months ago 3 Members · 2 Replies
  • Chris Borjis
    July 15, 2013 at 11:51 pm
    syncing via timecode or via audio in CC are options.
  • Herb Sevush
    July 17, 2013 at 1:45 pm
    [Gabriel Regalbuto] ” Can I easily create a multiclip timeline with matching code like in FCP7?”
    I believe there is a “flatten” feature in CC PPro that turns the multiclip timeline into a normal timeline that references original sources. Unlike FCP7 this is not a reversible feature, it’s like flattening in Photoshop.
    Herb Sevush
    Zebra Productions
    nothin’ attached to nothin’
    “Deciding the spine is the process of editing” F. Bieberkopf
