Activity Forums Adobe After Effects CC Force Motion Blur — can’t make it work
  • CC Force Motion Blur — can’t make it work
    Posted by V. Hunter mcenzie on December 21, 2005 at 4:20 pm
    I’d like to add some extreme mortion blur on a simple text tracking effect. I thought I just had to put the Force Motion Blur on an Adjustment layer above the text layer, but nothing’s happening. Any suggestions?
    Jonathan Miller replied 20 years, 9 months ago 4 Members · 6 Replies
  • Jeff Dobrow
    December 21, 2005 at 4:24 pm
    Try pre-comping it first….
  • V. Hunter mcenzie
    December 21, 2005 at 4:28 pm
    Ok, dumb question — Right now I have pre-comped the adjustment layer and the text layer into their own separate comp; is that not enough? Do I have to pre-comp just the text layer alone?
  • Jeff Dobrow
    December 21, 2005 at 4:48 pm
    Precomp whatever layers have motion (e.g. you are moving the text layer, so precomp the text layer WITH it’s motion keys) now apply the effect to the pre-comp. No need for adj layer…..
  • V. Hunter mcenzie
    December 21, 2005 at 5:13 pm
    I’m finally seeing a suggestion of blur — I think the motion is too subtle for this to really be noticeable. But thanks for the info on how to proceed; helpful for my next project.
  • Mike Procunier
    December 21, 2005 at 5:43 pm
    Apply the effect directly to the text layer & crank the shutter angle WAYup. Increase “Motion blur Levels” to smooth things out.
  • Jonathan Miller
    December 21, 2005 at 6:56 pm
    Mike’s right, it should do the trick if you crank it way up.
    Just don’t be surprised when you start scratching your head and looking at the render time.
    You may ask yourself, “Why is this 10 second animation taking 2 days to render?”!
    Jon
