Activity Forums Adobe After Effects CC Cylinder Layer Size Issue
  • CC Cylinder Layer Size Issue
    Posted by Michael Dodge on April 22, 2019 at 6:07 pm
    Hello All,
    Long time lurker, couldn’t find a similar thread that was solved with a similar issue at hand so I decided to open this question.
    I am having an issue with the CC Cylinder effect. I am animating an Ai file with multiple layers, but am finding an issue when I apply the CC effect to the layer (Fig1).
    Fig 1
    Fig 2
    The mock label that I am looking to animate has a layer size that fits to the artwork with no extra padding. When the effect is applied, the layer size prevents the effect from creating the full perspective effect. (Fig 2)
    I would appreciate any suggestions that would solve this issue. I am unaware of how to make the layer size larger, if that would solve this issue. I have also already tried an adjustment layer, but this creates another issue with the “body” of the bottle being below the label.
    I am running AE 16.0.1 on a Dell PC. Let me know if further PC specs are required.
    Michael Dodge replied 7 years, 4 months ago 2 Members · 2 Replies
  • Kalleheikki Kannisto
    April 23, 2019 at 5:36 am
    For the cut-off issue, you can precomp the layer (leaving all attributes) and then adjust the precomp dimensions to be larger.
    Senior Graphic Designer
  • Michael Dodge
    April 23, 2019 at 12:28 pm
    Kalleheikki,
    Thank you! That solved the issue! I only had one Ai layer that needed the effect and was apparently unaware that you could precomp a single layer.
    Cheers
