Activity Forums Adobe After Effects CC Cylinder (Coca Cola effect)- Rotating logo
  • John Cuevas
    October 2, 2013 at 3:28 pm
    If you mean the logo/bottle animation at the end, that was most likely done in a 3D app. That would be the easiest way to create that.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Elbire Rico
    October 2, 2013 at 3:40 pm
    Thanks for the reply. This is what i did.
    1.-I applied the CC Cylinder to the logo, and set the bottle as a track matte.
    2.- Precom the layers and convert it to 3d.
    3.- Finally I created a 3d null object to do the zoom effect.
    The problem is that when it zooms the bottle and logo don’t look sharp. I know it improves with the Continuous Rasterization but for that I need all the layers to be 3d, and that affects the track matte and the CC Cylinder.
    How can this effect be done in 3D??
