Activity › Forums › Adobe Premiere Pro › CC ctrl+D
  • CC ctrl+D
    Posted by Mike Cohen on October 10, 2014 at 9:05 pm
    Normally as long as the play head is at a cut, and the track is active, you can hit ctrl+D to apply default transition.
    Now it seems the two clips need to be selected. Is that the new normal?
    On the plus side you can select many clips and apply the transition to all selected cuts with one click, which is handy.
    Mike Cohen
    Ann Bens replied 11 years, 11 months ago 2 Members · 1 Reply
  • Ann Bens
    October 10, 2014 at 9:24 pm
    Behavior has not been changed. Did you target the track?
    Select many clips and add transition has been around since CS6. (add default transition to selection)
    Adobe Certified Expert Premiere Pro CC
    Adobe Community Professional
