Activity › Forums › Adobe After Effects › CC Ball Action doesn’t work on subcomp
  • CC Ball Action doesn’t work on subcomp
    Posted by Cugeeno Benatti on December 18, 2016 at 4:10 pm
    Hi everybody,
    I have a problem using the CC Ball Action in After Effects.
    I am working on a composition (Call it A) that contains another one with a green screen in it (Call it B). The main problem is that when I apply the CC Ball Action on the A comp, this affect the image except for the place where the green screen was. It looks like the plugin doesn’t recognize the precomp as a whole scene but it still analyze it as two different levels.
    Here a screenshot:
    Does anyone have an idea to fix it?
    Cugeeno Benatti replied 9 years, 8 months ago 3 Members · 4 Replies
  • Daniel Waldron
    December 18, 2016 at 7:31 pm
    Sounds like you have the Collapse Transformations box checked. A screenshot of your whole workspace could help identify if that is or isn’t the issue.
  • Cugeeno Benatti
    December 19, 2016 at 5:56 pm
    Hi Daniel,
    thanks for the answer.
    Here the workspace. On the left side the composition where I applied the green screen, on the right side the one where I applied the CC Ball Action. No Collapse transformation box is checked, still the green screen level disappears.
  • Walter Soyka
    December 20, 2016 at 10:57 am
    Is there a mask on that layer?
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Cugeeno Benatti
    December 20, 2016 at 11:26 am
    On the layers where I used the CC Ball Action there are no masks. In the subcomps there are some masks but not where the screen disappears!
