Activity › Forums › Adobe After Effects › CC Ball Action disable self shadow
  • CC Ball Action disable self shadow
    Posted by Artsiom Chikov on January 6, 2016 at 7:56 pm
    Hello!
    The whole day I’m trying to turn off the self shadow effect from CC Ball Action
    I tried to apply the Shadow/Highlight effect, change blending mode from normal to screen.
    I’m just want to get a solid matte color.
    I’m confused 🙁
    Please help
    David Cabestany replied 8 years, 11 months ago 3 Members · 3 Replies
  • Kevin Camp
    January 7, 2016 at 12:53 am
    this may work for you…
    try adding a gray solid (128 for all the rgb values, if working b-bit) and hide it.
    then add these effects to your ball-action layer (after ball action):
    • channel combiner
    • set channels
    • channel combiner
    things will look really crazy, so first set the ‘from’ property of the second channel combiner to ‘rgb to hls’ to get them looking back to normal.
    now in the set channels effect, set the ‘source layer 2’ property to be the gray solid.
    it should flatten out the luminance of the balls, but leave the colors. changing the luminance of the gray solid (in the solid settings) to make it darker or lighter can help to fine tune the values of the colors if needed.
    you could also try just using the color balance (hls) effect, increase lightness and saturation and see if that can get you close, pretty simple, but i don;t think it will be as successful.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Artsiom Chikov
    January 7, 2016 at 10:06 am
    That’s what I was looking for.
    Thank you!
  • David Cabestany
    October 20, 2017 at 3:46 pm
    Quick comment,
    it’s actually from HLS to RGB on the second Channel combiner, not RGB to HLS.
    Best,
    D.
