Activity Forums Adobe Creative Cloud CC app still seeing uninstalled CS6 apps
  • CC app still seeing uninstalled CS6 apps
    Posted by Oliver Peters on September 9, 2013 at 1:48 am
    I’ve deactivated and uninstalled the CS6 apps from my main machine, leaving only the CC apps. However the CC Desktop app still shows the CS6 apps in the panel and as “up to date”. Is there a way to remove these from the panel?
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
    Kevin Monahan replied 12 years, 8 months ago 2 Members · 3 Replies
  • Kevin Monahan
    September 10, 2013 at 10:25 pm
    Hi Oliver,
    Did you uninstall the apps using the uninstaller?
    If so, quit and restart the Creative Cloud app.
    if you uninstalled them a different way, they may need to uninstalled correctly to get them removed from the list. Uninstallers are located within the application folder.
    Kevin
    Kevin Monahan
    Social Support Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • Oliver Peters
    September 13, 2013 at 1:41 am
    [Kevin Monahan] “Did you uninstall the apps using the uninstaller?
    If so, quit and restart the Creative Cloud app.”
    Yes, I used the CS6 uninstaller. The situation corrected itself the next time I restarted the computer. Thanks.
    – Oliver
    Orlando, FL
  • Kevin Monahan
    October 3, 2013 at 4:25 pm
    [Oliver Peters] ” The situation corrected itself the next time I restarted the computer. Thanks.”
    Thanks for reporting back, Oliver.
    Kevin Monahan
    Social Support Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
