Activity Forums Adobe After Effects CC 2017 Avid DNxHD Alpha Bug
  • CC 2017 Avid DNxHD Alpha Bug
    Posted by John Cuevas on November 10, 2016 at 2:47 pm
    Regardless of choosing Pre-mult or straight all alphas coming out using the Avid DNxHD codec are coming out pre-multiplied. Also defaults everything to RGB color space. DNxHD works with both color spaces and it would be nice to have that option restored. If I’m missing a settings in the codec please let me know, but this is unacceptable.
    CC2017 – PreMult Alpha, Notice black line all around green box_RGB color.
    CC 2017 – Straight Alpha-black line all around green box_RGB color.
    CC 2015 – Straight Alpha- Clean all around, 709 color
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
    Jeremy Vannix replied 9 years, 7 months ago 3 Members · 2 Replies
  • Frank Feijen
    November 10, 2016 at 3:41 pm
    Same issue here, so it’s back to 2015…
  • Jeremy Vannix
    February 8, 2017 at 4:20 am
    I’m having the same issue. It’s also crazy that the color depth is locked at Millions of Colors with the DNxHR/DNxHD codec. Trillions of colors is standard for HD & UHD video.
    I wish they would just enable the old plugin in QuickTime codecs as before so you at least had the option to choose. This is really unfortunate.
    -Jeremy
