Activity › Forums › Sony Cameras › CB export to AVCHD
CB export to AVCHD
Posted by Robin Probyn on November 19, 2013 at 7:31 amThis option is greyed out for me.. how can I make that work.. ?
Robin Probyn replied 12 years, 10 months ago 2 Members · 4 Replies -
Ian Cook
November 19, 2013 at 3:14 pmonly works for avchd when you are writing back to media, not for XDCAM/EX/XAVC
if the option is greyed out, it’s not valid for the format you are working with. if it’s an export requiring the demo version of the Main Concept plugin the option will be active but you’ll be reminded at the next step that you are using a trial version. see ‘available functions by file format’ table in the help..
Robin Probyn
November 20, 2013 at 12:55 amOk thanks.. can you give a quick description of that plug in.. thanks again
Ian Cook
November 20, 2013 at 3:37 pmthe Main Concept plug-in? it’s an encoder by Main Concept that is used for all the transcode export options.
