Activity › Forums › Apple Final Cut Pro › Caution: Inspector parameters unresponsive in realtime since OS X 10.11.2 update.
  • Caution: Inspector parameters unresponsive in realtime since OS X 10.11.2 update.
    Posted by Tangier Clarke on December 11, 2015 at 5:03 pm
    I recently did the software update to OS X 10.11.2
    I know longer have realtime responsiveness from FCP X when making adjustments with parameters for effects, transforms or any parameters. I used to be able to see things happening while I make adjustments. Now I only see them after; and sometimes not at all.
    I am going to dump my FCP X prefs and see if that solves anything, but thought I’d let folks know.
    Tangier
    Tangier Clarke replied 10 years, 9 months ago 2 Members · 5 Replies
  • Tangier Clarke
    December 11, 2015 at 5:05 pm
    For the record it seems to be bound to one library and not others.
    Tangier
  • Bret Williams
    December 11, 2015 at 6:48 pm
    Still have the TC window bug?
  • Tangier Clarke
    December 11, 2015 at 6:52 pm
    Funny, I hadn’t noticed that it is in fact better. However not totally. It’s not clean like before the bug happened, but there aren’t as many strange lines anymore. Now there’s just a small spot over the last frame number space and a couple of spots that look like dead pixels – and they aren’t dead pixels.
    So it’s sort of fixed.
    Tangier
  • Bret Williams
    December 11, 2015 at 6:54 pm
    It actually changes every time you launch the app. But what about the words under the counter? Are they still misaligned?
  • Tangier Clarke
    December 11, 2015 at 6:59 pm
    Still misaligned.
    Tangier
