Activity › Forums › Square Box CatDV › CatDV/Premiere Pro extension question
Posted by Brad Baker on February 5, 2018 at 4:40 pmHow do you choose which CatDV details panel shows up in the Premiere Pro extension?
Josh Nikon replied 8 years, 3 months ago 3 Members · 3 Replies -
John Vaudin
February 5, 2018 at 6:23 pmNormally the Premiere Panel will show the same panels as the web client would. These are configured through the Panels section of the web admin UI. If you’ve got a reasonably new version of CatDV Server then you can specify a panel set specifically for the Premiere Panel by choosing Premiere Panel from the ‘client’ section of the visibility rules.
Brad Baker
February 7, 2018 at 5:57 pmGreat, thanks John. I was able to set it up in the Server visibility rules.
Josh Nikon
June 12, 2018 at 3:15 pmI don’t mean to hijack.. but I have not been successful at getting the p.panel to connect with the server. I put in the ip and it just sits.. am I doing something wrong? Is there a trick to it?
