Activity Forums Square Box CatDV CatDV Worker and FFmpeg not getting along?
  • CatDV Worker and FFmpeg not getting along?
    Posted by Martin Newsome on October 24, 2011 at 4:41 pm
    When passing a conversion to FFmpeg if the file is too large FFmpeg will hang half way through and does not exit properly. The process must be killed to continue the CatDV Worker Node workflow; resulting in a corrupt/incomplete file.
    From the command line FFmpeg works perfectly when issuing the conversion command shown below. That being said, I put the command for FFmpeg into a shell script, so that CatDV executes the script not FFmpeg directly. This did not resolve the problem. If the same script is executed from the command line FFmpeg will complete the task.
    When used with a Watch Action on CatDV Worker Node, that’s where the problem is.
    I really hope I’m just missing some check box or something. Any ideas?
    Thank you.
    M
    = = = = Information = = = =
    Input file
    MPEG-4 H.264 Baseline
    1024 kbits/sec
    640×360 Letterbox
    Frame Rate 24
    Key Frame 24
    Audio AAC-LC
    96 kbps
    Stereo 44.100 kHz
    File sizes
    35MB works fine
    122MB fails
    Watch Action / Conversions / Execute command 1: ($g = base filename of input)
    /usr/local/bin/ffmpeg -i /directory/$g.mp4 -acodec libvorbis -ac 2 -ab 96k -ar 44100 -b 1024k -g 24 -s 640×360 /directory/$g.webm
    Software
    Mac OS X Server 10.5.8
    CatDV Worker Node version 3.1.0
    FFmpeg version 0.8.5
    libtheora-1.1.1
    libvorbis-1.3.2
    libvpx-v0.9.7-p1
    Hardware
    Xserve 2×2.66 Quad-Core Intel with 12GB of RAM
    Martin Newsome replied 14 years, 9 months ago 2 Members · 2 Replies
  • Bryson Jones
    October 24, 2011 at 7:56 pm
    I’m assuming the usual escaping of spaces etc has been done so I’ll just share what I’ve seen.
    I’ve seen timeout errors in shell commands from Worker myself.
    Curl would timeout on large ftp transfers, for instance.
    But once it’s passed to a script I’ve not seen failures since the shell completes or does not, generally.
    For something that simple you could just use a cron job (or similar function) on a folder and remove the Worker completely, if you had to, but obviously a variable passed to a separate shell script should work
    Let’s see what the support team has on this.
    bryson
    bryson “at” hidefcowboy.com
    hidefcowboy.com
  • Martin Newsome
    October 24, 2011 at 8:54 pm
    The first watch folder pulls the file to a different system and replaces the spaces with underscores. Preforms a “conform” for the rest of the workflow… poster images, multi-formats, etc. This one little bit is the only part that stops the process. Weather or not it’s called from Worker or a shell script. On it’s own the shell script works fine, it’s just when Worker Node executes it that it fails. … driving me crazy. 🙂
