Activity Forums Square Box CatDV CatDV – Tagging Clips workflow
  • CatDV – Tagging Clips workflow
    Posted by Ace Billet on January 2, 2014 at 6:31 pm
    I’m testing CatDV before a purchase.
    Read the manual, just making sure I have the workflow right:
    The tagging takes place under “Log Notes”.
    You can add “Notes” or use the “user” fields for adding specific notes,
    renaming the user fields to “Shot Type” “Participant” “Action” etc.
    Is this correct ? I know the cat, its skin and methods.
    Dougal Matthews replied 12 years, 8 months ago 2 Members · 3 Replies
  • Dougal Matthews
    January 7, 2014 at 4:34 pm
    hi Asaf
    it sounds like you’ve got a good grasp of the concept
    there’s lots of really useful stuff on our website in the tutorials section
    https://www.squarebox.com/catdv-tutorials/
    the subsection on getting organised has lots of info about customizing metadata ( user fields ) setting up views and logging
    hopefully this will guide you through the process and sugest some ideas that you can adapt and modify for your own implementation
    Cheers dougal
    Improvise Adapt and Overcome
  • Ace Billet
    January 7, 2014 at 4:52 pm
    Holy Cat. Going through this !
    Anther methodial question – What’s the “right” or safest way to work ?
    Organizing Catalog Files by projects ?
    Then “Browse Catalogs” when necessary ?
    I’ve read it’s not advisable to put too many clips in the Catalog.
    thanks
    AB
  • Dougal Matthews
    January 7, 2014 at 5:24 pm
    unfortunately given the variety of different workflows and the many parts of the catdv tool set i don’t think there can be a single “right” way of doing things.
    certainly organizing catalogs by projects fits with the way people think so it tends to be intuitive and as all searches can be across all catalogs you can use keyword searches to create collections of media or open catalogs to browse or filter the clips.
    In order to keep things responsive and manageable we recommend that a catalog should have no more than 3-5000 items inside, although some people get away with having far larger collections at some point performance will become compromised.
    cheers Dougal
