Activity › Forums › Square Box CatDV › CatDV server upgrade error
  • CatDV server upgrade error
    Posted by Yannick Guillerm on October 11, 2011 at 6:12 pm
    I just downloaded the latest version of CatDV Server (6.6b7). When starting the CatDV Server, it requires a database upgrade as the format has changed (I guess). Well when I’m doing it I’m getting the following error:
    An error occurred: an unsafe statement written to the binary log using statement format since BINLOG_FORMAT=STATEMENT. Statement is unsafe because it uses a system function that may return a different value on the slave.
    Upgrade seems to be from 3.21 to 3.22.
    Any ideas?
    Thanks.
    Yannick Guillerm
    System Engineer
    Atempo Inc
    yannick.guillerm@atempo.com
    650-812-3056
    Rolf Howarth replied 14 years, 11 months ago 2 Members · 2 Replies
  • Yannick Guillerm
    October 11, 2011 at 8:31 pm
    Well, I did a server reboot at a point an seems that issue did resolve by itself. Kinda weird. My CatDV server is now up and running.
    Yannick Guillerm
    System Engineer
    Atempo Inc
    650-812-3056
  • Rolf Howarth
    October 12, 2011 at 9:24 am
    I’m not sure why that would occur. Are you using replication? In any case, the 3.22 schema is quite trivial, it just adds an extra constraint for debugging, so is far from essential.
