Activity Forums Square Box CatDV CATDV on an Edit Share System
  • CATDV on an Edit Share System
    Posted by Jordan Bosch on August 27, 2012 at 5:32 pm
    Hi Guys,
    Just about to install our CATDV System with an LTO CACHE-A and a bunch of other goodies. One question that is popping up is how CatDV will work with our current Editshare system set up. Has anyone set up CAT-DV with Editshare? Any quirks we should watch out for? Or will nothing change.
    Thanks for any input!
    Jordan Bosch
    Zoomwebvideo.com
    Bryson Jones replied 14 years ago 2 Members · 1 Reply
  • Bryson Jones
    August 29, 2012 at 1:28 pm
    CatDV works with any mountable filesystem. It really doesn’t care.
    The performance and permissions of the storage apply. If it’s fast, you can play hires media, if it’s slow, you cannot.
    If you have write permissions, CatDV can move and add things, if you only have read, then CatDV has read.
    CatDV is “compatible” with everything from a USB stick to a million dollars worth of DDN drives. Let us know how it goes.
    bryson
    bryson “at” northshoreautomation.com
