Activity Forums Square Box CatDV CatDV crashed when hitting save
  • CatDV crashed when hitting save
    Posted by Jeanine Strock on August 10, 2011 at 6:08 pm
    I was just looking through a catalog that someone had just finished adding data. I was making corrections, hitting save as I went. I hit save and KABOOM. All the files and data were gone. There was no undo.
    I looked in the Audit Log and it shows a simultaneous “publish changes” and “Delete clips” at 13:33:36.
    Is there a way to find back-up files on the server somewhere?
    Jim Young replied 15 years, 1 month ago 3 Members · 2 Replies
  • Rolf Howarth
    August 10, 2011 at 6:57 pm
    Hmm, that sounds odd, so I don’t know what would have happened there. You mean the application itself crashed? Make a copy of the CatDV Error Log and backup from Home > Library > Logs (if you’re on a Mac, or inside your local appdata folder on Windows). Also, please save a copy of the server log and send them all to support@squarebox.com. If you deleted clips on the server (for whatever reason) they should have been saved to the recycle bin. I’m sure the media files themselves won’t have been deleted.
  • Jim Young
    August 10, 2011 at 7:32 pm
    Rolf,
    Just emailed you the log files requested to support.
    -Jim
