Activity Forums Square Box CatDV CatDV ‘Copy Media Files…’ making proxies offline
  • CatDV ‘Copy Media Files…’ making proxies offline
    Posted by Chris D’agorne on July 3, 2012 at 9:44 am
    Hi, thanks in advance for any advice you can give…
    I’m working with CatDV Pro 9.0.6 and we’re implementing an LTO Tape-based archiving procedure. As part of this, we’ve imported a collection of archived media folders from various external hard drives into CatDV and then used the software to create Proxy media. This process worked perfectly; however, when we then use CatDV to ‘Copy Media Files…’ to our LTO tape and select the ‘Update clips so they refer to new copy’ option, CatDV copies all our media into one folder on the LTO tape, meaning not only that the proxy media is now offline (as it is arranged in the same folder structure as the media on the original volume), but also that any files with the same name as other files in our folder structure (e.g. we have more than one MVI_0001.MOV due to now-redundant filenaming procedures) are not copied across, requiring a laborious process of going through the folder to identify any media which hasn’t copied across and then creating folders to copy it into.
    Is there any way of preserving the folder structure when copying across media with CatDV, or relinking to proxy files when they are arranged in a different folder structure? Or just getting CatDV to work a bit more efficiently with this workflow?
    Many thanks!
    Chris
    Bryson Jones replied 14 years, 1 month ago 3 Members · 2 Replies
  • Rolf Howarth
    July 3, 2012 at 1:40 pm
    I’m afraid that currently the Copy and Move Media Files commands don’t preserve the folder hierarchy (except in the case of P2 metaclips, where you can use it to copy clips from one card to another for example). You could do what you want using the CatDV Worker Node or the Archiving Option, though both of those involve an extra cost.
  • Bryson Jones
    July 3, 2012 at 5:15 pm
    This is one of the single most compelling reasons to have the Worker Node.
    bryson
    bryson “at” hidefcowboy.com
    hidefcowboy.com
