Activity Forums Square Box CatDV CatDV and MySQL install location
  • CatDV and MySQL install location
    Posted by Will Duncan on May 11, 2013 at 7:40 pm
    Does CatDV require that you use the default Mysql installation?
    I’m attempting to migrate CatDV to a Mac Mini Server running mysql installed with homebrew (https://mxcl.github.io/homebrew/) which runs in /usr/local/Cellar/mysql/ but you cannot even run the CatDV server DNG without the textboot default mysql installed.
    Bryson Jones replied 13 years, 3 months ago 2 Members · 1 Reply
  • Bryson Jones
    May 12, 2013 at 4:59 pm
    It can be moved but it’s way easier just to use the default location.
    If you’re not using that original install of MySQL, you can just re-install in the default location and things work fine.
    On our systems that use Approval-Q, we install a separate instance of MySql to run the AQ database (for separation and security) with no ill effects.
    If you need it configured, it’s hard to find a tech who’s fluent in both to make the necessary adjustments, though I believe the server read me might address it somewhere. I say keep it simple unless you absolutely must share that install of SQL.
    bryson
    bryson “at” northshoreautomation.com
