Forums › Square Box CatDV › CatDV 9 Server -Query
bryson jones
January 5, 2016 at 9:43 pmThat is weird. v9 should be able to do that though.
You could also use Media Folder to filter that will let you choose the drive/path. I know that that is available in v9, we’ve used it for years.
bryson
bryson “at” northshoreautomation.com
Brad Starkey
January 6, 2016 at 3:03 amDid you try to filter if it’s online from the tree? It’s on the left side of the interface. I’m not sure if the search bar works or not to filter online. But it’s pretty powerful to use this alternate approach to filter all sorts of criteria.
Pierre Valliere
January 6, 2016 at 3:48 pmThx Brad, I’ll use the filter in the tree. I would like it to work in a Query, but the result is the same. Thx guys for the anwsers!
Ben Sturgis
December 9, 2022 at 4:16 pmIF I run a DAM system with CatDV backend and Akomi web server. We have about 32TB of
nearline storage and a LTO tape library. We ingest about 1 TB of media per week
into our library. The CatDV makes a few different mp4 versions of the files and
uploads them to Akomi. At the same time, we archive the high-res files to LTO.
After a few weeks, as our storage gets filled, we delete the high-res files
from storage after we confirm that they have been archived properly. Most of
this is automated in CatDV, but occasionally we like to go through and check to
make sure that nothing is missed. That’s why I was looking for a query method
to easily see which files were still online but may not have been archived
yet.Is there an alternative method to querying the ‘online’ field?
Log in to reply.
