Activity › Forums › Square Box CatDV › Cat DV XMLs not exporting correctly
Posted by Dan Lewis on July 2, 2015 at 6:31 pmBryson Jones replied 11 years, 2 months ago 3 Members · 10 Replies -
Bryson Jones
July 6, 2015 at 5:23 pmI’m sure support will chime in, but first check your CatDV preferences/settings for your version of Premiere and then also check your CatDV version.
I know that there was an Adobe Update recently that changed a few things.
bryson
bryson “at” northshoreautomation.com
Dan Lewis
July 6, 2015 at 5:58 pmThanks for the response Bryson, it looks like this may have been a plugin issue, Cat DV couldn’t detect the TC in my MXF files. I have found a plugin on Sony’s website that seems to have helped, albeit in a slightly clunky way (Cat DV can now see the TC but can no longer create thumbnails automatically from these files, not sure why).
Dan
Bryson Jones
July 6, 2015 at 10:56 pmI’ll take a crack at it.
It’s really not “the MXF option” in a way. If you have the correct codecs and drop a single muxed MXF file into “regular” CatDV, it should play so you can deal with certain types of MXF without it.
Also, “the MXF option” doesn’t give you any codecs so you still need to buy and or install any of those that you need.
“Then what does it do”, you might be asking?
“The MXF option” should be called, “the option that lets CatDV take MXF formats that aren’t a single file and import them as a clip or clips that you can play and manage as assets.” But that’s long and lame and so it’s called “MXF option.” 😉
If you look at a P2 or XDCAM folder structure out of the camera, there’s dozens of files that combine to make maybe just a few clips. The video and audio and metadata are all separated out and the metadata is often in an attached XML file. “The MXF option” allows CatDV to read the metadata and gather the essence files together and present them as playable clips that can also be managed as a clip instead of a bunch of files and folders.
You might call it “The MXF grouping option.”
Hope that helps.
bryson
Dan Lewis
July 7, 2015 at 8:57 pmSo do I have to purchase the Cat DV option before I purchase any codecs?
Paul Douglas
July 13, 2015 at 9:04 amHi Dan,
Sorry to hear that you are having issues with exporting your XML files. Could you please drop us an email at support@squarebox.com and we will address your XML issue there.
Kind Regards
Paul Douglas
Square Box Systems LtdPaul Douglas – Support Engineer – Square Box Systems Ltd
Bryson Jones
July 13, 2015 at 5:37 pmYou can download free or trial codecs as they are completely separate from CatDV. If you do choose to purchase codecs, as opposed to the MXF option in CatDV, they might come from Sony, Calibrated or MOG or someone like that.
bryson
Dan Lewis
July 14, 2015 at 3:22 pmThanks Bryson,
I think I have got a solution for this now, I was able to use some external codecs and this seems to have filled the gaps.
Dan Lewis
July 14, 2015 at 3:24 pmThanks Paul,
I think I have found a solution. It appears to have been a missing codecs problem, the XMLs needed TC but CatDV couldn’t detect TC from MXFs without the correct codecs.
Dan
Bryson Jones
July 14, 2015 at 4:27 pmExcellent, hope this cleared things up. You can do so much with CatDV Pro, right out of the box.
bryson
