Activity Forums Square Box CatDV Cat DV Player and Database issues
  • Cat DV Player and Database issues
    Posted by Vance on June 11, 2012 at 3:40 pm
    I am playing with CatDV in an attempt to learn a bit more of the Digital Asset Management concept. I have made several catalogs, about 6 now. Yesterday I started another catalog, dropping a few thousand files into it. After a short interval the clips were all neatly cataloged.
    However that is when the issues started. Previously I was able to double click on any on-line clip and have it play in the interface. Now, however, I get only the following error message:
    Failed to show media (Failed to open movie using QT or JMF)
    The clip is there, I can do a command L and play it in quicktime without problems.
    Then, before I left last night I sent CatDV off to make proxies of all the new media. This morning, I still can’t play the clips. I opened an older catalog, and find that the proxies are now cross linked to those clips. Double clicking on a clip from a completely different client opens the poxy from last night.
    So my usual solutions to problems, deleting pllist files and uninstalling and re-installing are not of any use. I did not find a preferences file, and a delete and reinstall does not change the behavior.
    Any ideas?
    -Vance Piccin
    Robb Harriss replied 14 years, 3 months ago 2 Members · 4 Replies
  • Robb Harriss
    June 11, 2012 at 4:22 pm
    where are the files stored? Locally or on the network?
    what format are the proxies?
    and are you making tape-based or path-based proxies (in the proxy/thumbnail settings)
    Non-linear: all the time and nothing but.
  • Vance
    June 11, 2012 at 4:53 pm
    I am using the standard version of CatDV on a single machine. All the files are local to that machine. The proxies are M-Jpeg, which I believe is the default for the program. In the Proxies & Thumbnails preferences Based on tape & timecode and Based on path are both checked. Prefer path is not.
    If it is important this system is on a Lion (10.7.4) Mac.
  • Vance
    June 11, 2012 at 5:05 pm
    Oh but wait…
    I reset the preferences to factory default, and low and behold my media viewer is back. The default is path based and prefer path. I deleted the proxy media from last nights run, so am rebuilding that now.
    Thanks Robb, that seems to be the hint that put me back on track.
  • Robb Harriss
    June 11, 2012 at 5:39 pm
    path is what you want. It makes a lot more sense as you work with it.
