Activity Forums Adobe After Effects Casting 3D shadows on AE produces artifacts
  • Casting 3D shadows on AE produces artifacts
    Posted by Daniel Sánchez de miguel on September 12, 2012 at 7:22 pm
    Hi all,
    I’ve got a comp with some images being dropped or slide on top of a background. There’s a camera with a slight move that creates the 3D space. Objects are well distributed so they don’t overlap in the “x” axis. There’s a spot light that creates a vignette effect and also allows the objects to project 3D behaving shadows over the background.
    Once the objects land on the background the camera move remains and here is where I am seeing waving artifacts on the edges of the shadows. I’ve tried putting shadows with Layer Styles and these look fine but don’t behave the way I’d like. I am rendering Animation so output quality is not the issue, as far as I know.
    Is this a common problem with 3D cast shadows in AE? This is AE 5.5 btw.
    Here’s a link to the file. First Picture is in shadow only mode so the problem it’s seen more clearly.
    https://www.dropbox.com/sh/0un5gavwz6tw5sn/F4WKLZ0Tb7
    Thanks for your help!
    Daniel
    Mathew Fuller replied 14 years ago 2 Members · 1 Reply
  • Mathew Fuller
    September 12, 2012 at 8:46 pm
    Shadows can do this in AE in these instances where 2 flat planes are really clise together ( like a piece of paper on a table). Try giving them a little more space to breathe.
    My Work:
    https://www.morecompletefx.com
