Activity › Forums › Adobe After Effects › cartoony tornado
cartoony tornado
Posted by Graber on February 22, 2007 at 1:23 amHey I am trying to figure out how to make a tazmanian devil-esque tornado thing… any ideas?
Graber replied 19 years, 7 months ago 3 Members · 4 Replies -
Hans Van vliet
February 22, 2007 at 1:44 amHave you tried using the scribble plugin? Setting it to about 35/45deg and making the stroke thick controlling it with a tringle like mask?
..::hunz
Nate Vander plas
February 22, 2007 at 3:11 amOk, try this. Make a new solid and mask out a hollow loop in the general shape of your tornado as seen from the top. Make the anchor point slightly off center and animate the loop to rotate for a bit longer than you’ll need it to. Then apply a wiggle expression to your solid. Pre-comp the solid (this might not be necessary, but I’m not sure) then make the pre-comp 3D. Rotate it to where you want it (the top of the tornado). Then duplicate it many times (20 or more, probably) and adjust the position and scale so that each one down is a little smaller. You will also need to apply some color correction to vary the color from black to gray to white (or brown). Then move the entire clip of each duplicate a litte forward/backward in the timeline. If you stagger them you might be able to get a wavy effect. This is hard to explain, so if you have questions ask. I will probably try this myself tomorrow (I don’t have AE on this computer) and see if it actually works!
Nate Vander plas
February 23, 2007 at 5:39 amAlright, I tried it and it worked pretty well, actually. Somewhere between cartoony and CGI, but you might be able to adjust some things to get the look you want. Here is the project file:
https://natevplas.googlepages.com/aftereffectprojects
Just click on “tornado.aep” and download it. Hopefully you have AE 7, cuz that’s what I made this in. If this isn’t at all what you’re looking for, oh well, I had fun making it!
Nate -
Graber
February 23, 2007 at 3:14 pmthanks!
I really apreciate the help… I will work on it tonight and let you know how it turned out!
