Activity › Forums › Adobe After Effects › Cartoonification (Podcast) Problems
  • Cartoonification (Podcast) Problems
    Posted by Andy Brown on September 2, 2008 at 8:45 am
    Hi Guy’s
    the tutorial is brilliant and the effects I’m getting are great but there are a couple of problems:
    1. illustrator is cutting off the left and parts of my vid so I end up with black bars on both sides
    and
    2. the accent part of the project, when I apply the effect to the frames in bridge it’s not what it looked like in illustrator it’s coming through a lot darker than the original preset
    Any ideas?
    Thanks in advance
    Andy
    Simon Bonner replied 18 years ago 2 Members · 1 Reply
  • Simon Bonner
    September 2, 2008 at 10:31 pm
    It’s been a while since I ran through this tutorial, but you may be having problems with cropping because your work area (that may not be the technical term – anyway, I mean the ‘paper’ size) in illustrator is not wide enough. Try resizing it before you start processing the frames – I think that might be what I did. If I remember correctly, it doesn’t have to be the exact size of the frame, just large enough for the frame to fit into. Good luck!
    Simon Bonner
    youtube.com/simonsaysFX
