Activity Forums Adobe After Effects Cartoonification
  • Cartoonification
    Posted by Eric Klassen on June 22, 2010 at 5:02 pm
    I’m working in CS4, following Aharon Rabinowitz’s tutorial to do cartoonification. I noticed the tutorial was created for CS2… Is there an updated work flow for CS4 to create this effect?
    Eric
    Eric Klassen replied 16 years, 3 months ago 2 Members · 2 Replies
  • Todd Kopriva
    June 22, 2010 at 7:00 pm
    You mean like the Cartoon effect, which was added in After Effects CS4?
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Eric Klassen
    June 22, 2010 at 8:49 pm
    Yes, I found the cartoon effect and it seems to do the same thing. Thanks. I ended up being able to do a key and apply a stroke which gave a much more controlled line.
    Eric
