Activity Forums Adobe After Effects cartoon style
  • cartoon style
    Posted by Mats Andresen on May 8, 2008 at 11:44 pm
    Howdy Cow!
    I am looking for a way to ad a subtile shaking motion to some illustrator drawings. I have only drawed one frame and now I would like to add some motion to them to make them look a bit like old rotoscope/animation stuff.
    Can anyone recomend me a pluggin or a technique ?
    Sincerely
    Mats Andersen
    Simon Bonner replied 18 years, 4 months ago 3 Members · 3 Replies
  • Simon Bonner
    May 9, 2008 at 10:20 am
    Hi Mats,
    It sounds like you want it to ‘boil’. Boiling makes otherwise stationary objects look like they’re moving and can make animation more dynamic, but it’s essentially an artefact. The easiest wasy to achieve it is to draw two or three versions of the same picture and then play them one after the other (2 – 3 frames each, or you can experiment to see what works best). Because your pen will be slightly off target each time, the lines that make up the drawing will appear to move, or ‘boil’.
    To achieve this in AE, import your 2 or 3 frames as an image sequence and then use the interpret footage dialogue box (I think this is where the option is) to loop the sequence as many times as necessary (I usually just give it a very high number). Then when you drag the layer out in the timeline, it will continually boil.
    Hope this is what you mean.
    Simon Bonner
    youtube.com/simonsaysFX
  • Mats Andersen
    May 13, 2008 at 7:39 pm
    I ended up using the wiggler.
    The result was ok – but I wish there was a pluggin that easy gave more variations to the boiling. Drawing was not an option on this project.
  • Simon Bonner
    May 14, 2008 at 8:12 am
    You could use thee turbulent displace effect, animate the evolution property, and switch the frame rate way down so the smoothly changing distortion becomes choppy.
    Simon Bonner
