Activity Forums Adobe After Effects Cartoon look
  • Cartoon look
    Posted by Jeremy Patterson on January 25, 2019 at 3:16 am
    Hello all. I’m trying to adjust the toon filter so it’s looks like a cartoon or anime. I know that anime look consists of flat colors and defined lines that outline the body etc. What settings would you recommend to get flat colors and lines like that? Thanks.
    Max Haller replied 7 years, 7 months ago 3 Members · 2 Replies
  • Stephen Smith
    January 25, 2019 at 4:01 pm
    The toon filter is extremely limited in what it can do. You will never be able to take live action footage and make it look like the sample you provided.
    Stephen Smith
    Utah Video Productions
    Check out my Vimeo page
  • Max Haller
    January 28, 2019 at 4:52 pm
    Agreeing with others I don’t think you’ll have much luck with the toon effect. Now the toon shader in C4d can give you some more useful results but it will obviously be much different then trying to apply a filter to footage you might have. You’d have to model everything and animate it all in Cinema, but it can output a cool cartoon style
