Activity Forums Adobe After Effects Expressions Carriage Return in CSV linked data?
  • Carriage Return in CSV linked data?
    Posted by Paul Connors on March 2, 2021 at 10:00 pm
    Hello. I’m looking for a way to include a carriage return in a spreadsheet cell (CSV) that I can link to an After Effects project. I essentially want to be able to have two names stacked on top of each other in one spreadsheet cell and therefore in one text layer in AE. Each time I try to add a carriage return in the CSV file it breaks the data connection on the AE side. I’ve done a bunch of research online as well, but haven’t been able to find any answers, hence posting in this forum. Any help would be greatly appreciated. Thank you!
    Trent Armstrong replied 5 years, 6 months ago 4 Members · 3 Replies
  • Dan Ebberts
    March 2, 2021 at 10:08 pm
    I guess you could use a character in the spreadsheet that wouldn’t otherwise appear in your text (like “|” maybe) to indicate a carriage return and then replace it with an actual carriage return in your text expression.
  • Kevin Camp
    March 2, 2021 at 10:18 pm
    In the spredsheet cell, are there two names in the cell. like ‘John Doe’?
    If so, you could parse the sourceText for that text layer and replace the space with a carriage return.
    Here is a simple expression to do that:
    txt = value.split(" ") ;
    txt[0] + '\r' + txt[1]
    However this may not work if there is more than two words in the cell… ex: ‘John Doe Smith’.
    If you can insert a less common character in the spreadsheet to use to determine the break it would give you better control… like add a ^ where you want the break, then change the expression like this:
    txt = value.split("^") ;
  • Trent Armstrong
    March 3, 2021 at 5:34 pm
    Can you put \r in your CSV file where you need carriage returns and have that just flow through to AE?
