Activity Forums Adobe After Effects Card wipe using a gradient for wipe direction
  • Card wipe using a gradient for wipe direction
    Posted by Bill Mckown on November 15, 2008 at 6:20 pm
    Hi all,
    I’d like to take an image (single layer) and do a card wipe to black using the random card flips but I’d like to have it start at the right side and move to the left as it radomly swaps cards.
    I have what I want now, it looks like at explosion of cards that fade to black, except I’d like the explosion to move from right to left. I’ve tried using a gradient layer but the flip order won’t change to “gradient” (it stays set at “btm right to top Right”). Maybe I’ve missed a setting but I can’t seem to find in in the help file.
    Bill
    Bill Mckown replied 17 years, 9 months ago 3 Members · 4 Replies
  • Steve Rhoden
    November 16, 2008 at 12:34 am
    Have you tried playing around with the shatter plugin?
    I am sure you can tweak and get the look you want.
    Steve Rhoden
    (Cow Leader)
    Creative Arts Director and Film Maker.
    Portfolio at:
    http://www.youtube.com/hentys
  • Bill Mckown
    November 16, 2008 at 3:07 pm
    I thought there was a simple setting I missed with card wipe. I reopened the file and now I’m able to select using a gradient, but it still won’t work!
    No I haven’t tried shatter, but I’ll give it a try…
    Bill
  • Brian Charles
    November 17, 2008 at 12:45 am
    Simply set transition completion to 100% then animate it to 0%, the transition will move right to left.
  • Bill Mckown
    November 17, 2008 at 1:16 am
    Thanks but this doesn’t work it still gives a random wipe. There is some kind of a built-in expression under “transition completion” controlling this, so I can animate 0 to 100% but it doesn’t make it change directions.
    This is the expression:
    transComplete = effect(“Card Wipe Master Control”)(“Transition Completion”);
    linear(transComplete, 0, 33, 100, 0)
    However, I did figure it out by using an animated gradient layer that moves from right to left, (I had to disable the built-in expression under “Flip order”) and calling out “gradient” then the layer name. Now it works basically the way I wanted.
    Bill
