Activity › Forums › Adobe After Effects › Card Wipe crash
  • Card Wipe crash
    Posted by David Eells on May 9, 2007 at 3:57 pm
    Can’t find mention of this in the forums – Whenver I invoke Card Wipe it crashes After Effects 7.0. I booted from a “cleaner” partiton (a stripped down startup drive just for emergencies) and it even crashes 6.5.
    Anyone else have this problem? System’s great otherwise:
    G5 DP 1.8
    2.5 gb ram
    OSX 10.4.8
    David Eells replied 19 years, 4 months ago 2 Members · 2 Replies
  • Kevin Camp
    May 9, 2007 at 4:43 pm
    do you have opengl preivews enabled?
    check ae>preferences>preview and disable opengl. that may be causing issues, and if you have a g5 with an agp slot, you won’t want to use opengl anyway (the mac agp cards don’t support opengl 2.0 features, so you won’t get things you need like anti-aliasing and motion blur).
    even if you have a g5 with pcie slots and an ati x1900 card (i think the only opengl 2.0 for a g5), you may want to disable opengl when you notice problems. many disable it regardless, because opengl can just be tweaky.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • David Eells
    May 11, 2007 at 2:02 pm
    Thanks – no I never use openGL. My graphics card is GeForce FX 5200, and I’m pretty sure I’ve used this in the past. Turns out I can put the effect on a color solid, but not on anything else.
