Activity Forums Adobe After Effects card dance to pull apart halftone image
  • card dance to pull apart halftone image
    Posted by Michael Duff on May 30, 2006 at 6:09 am
    hi all – I’m considering using card dance to “pull apart” a halftone photo of a girl. So each ‘card’ has a single dot on it that can fly around. Problem is I have hundreds of dots making up this half tone. They are evenly spaced. But I can’t get the grid to match up in card dance. Does anyone suggest a better way to make this work rather than trial and error? I can get my grid very close to correct but then it is incorrectly aligned with the dots…..
    Sean Bowerman replied 19 years ago 5 Members · 5 Replies
  • Mike Clasby
    May 30, 2006 at 6:40 am
    Methinks you need to count the dots in your halftone, width and Height, hey aren’t they come n-dots per inch? Anyway then you can set up your card dance grid with the correct numbers.
  • Steve Roberts
    May 30, 2006 at 12:25 pm
    You could also try Shatter, using the halftone image as a shatter map.
  • David Bogie
    May 30, 2006 at 4:25 pm
    I’d use Ball Action.
    bogiesan
  • Michael Duff
    May 30, 2006 at 10:06 pm
    cheers – will try all these methods….Steve, often when I use a shatter map that is exactly the same as object I get lost pieces that just fly around – like the map isn’t matching up correctly. But it must be cause all I do is desaturate the same image.
  • Sean Bowerman
    September 11, 2007 at 11:00 pm
    hey, i have a very similar job i’m doing now, and i just wondered how you managed to solve the problem… i have a client logo that is made up of hundreds of dots, and i want to drop the dots in randomly from above… any advice would be greatfully received. thanks in advance.
