Activity Forums Adobe After Effects Card Dance / AE CS4 / 16-bit project render problem…
  • Card Dance / AE CS4 / 16-bit project render problem…
    Posted by Shane Walker on June 22, 2011 at 9:00 pm
    So, running AE CS4 on a 32-bit Windows XP system, and same on another Windows 7 Pro 64-bit system and I’m getting the same problem. I’m encountering an odd rendering issue w/ a project I originally set up as 8-bit 1080 23.976 using the Card Dance effect to create one of those splendid ‘exploding mosaic of pictures’ moments in an animation. All was well, doing refinements/retimes/iterations, until…
    I switched the project over to 16-bit to alleviate banding in the soft lighting effects and gradient backgrounds of my composite. Now, suddenly, the Card Dance layer’s animation renders with a judder all across the various tiles, making them pop forward/back in Z-space, almost like a time-shuffle of their animation. Weird. Switching the project back to 8-bit and re-rendering makes the issue go away, btw. I checked, and have tried rendering w/ and w/out OpenGL turned on, and there’s no other filter on the layer, nor does it have ‘continuously rasterize/collapse tranformations’ turned on.
    My only idea is to see if it will render on my Win7 64-bit in AE CS5 alright. Maybe I’ve just hit a bug in mixing all those ‘bits’? 🙂 Any ideas!?
    Tudor “ted” jelescu replied 15 years, 2 months ago 3 Members · 5 Replies
  • Michael Szalapski
    June 22, 2011 at 9:22 pm
    You could certainly try it on the newer suite and see what happens.
    Also, you could render the background separately from the card dance and comp them together.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Shane Walker
    June 22, 2011 at 10:17 pm
    That is a decent work-around. Beats rendering the entire comp out in 8-bit, which I had done, then dissolving between the two at the most opportune edit point.
    Still–as a matter of principle, I’d love to know where exactly the bug resides, if only to know how to avoid this particular pitfall in the future, y’know?
  • Tudor “ted” jelescu
    June 23, 2011 at 6:23 am
    You could do a test and start a project from scratch in 16 bit to see if it acts the same way- it will help narrow the issue.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Shane Walker
    June 23, 2011 at 7:36 pm
    Ted! You sly dog you…what a concise logical step. I also was going to load up the project under AE CS4 Mac and render a test, just to see if OS/drivers were somehow part of the prob. Pays to dual-boot I guess!
    Good to cross paths w/ you again in ‘the Matrix.’ 😉
    June 24, 2011 at 5:50 am
    I just had to post something to cause a response- good to see you around!
    Tudor “Ted” Jelescu
    Senior VFX Artist
